So I went to winterize my boat and I noticed as in the past the antifreeze was a little low and this has been a summertime issue after replacing the head gasket exhaust gasket the intake gasket and exhaust riser gasket . Every time I start up the boat you can clearly see the antifreeze shooting out of the exhaust it lasts for about 10 seconds and it's pretty much the same amount that's missing 1 pint . So somehow any phrase is leaking I guess into the exhaust add when you start the boat shoots out the back . Do you think it’s the exhaust riser gasket (new) failed . I may redo the riser and exhaust gasket next spring
