RandyJ
Master Chief Petty Officer
- Jun 13, 2002
- 808
It has probably been 40 years since I last used one of these. I tried to find a manual online to refresh my memory on how to use it and how to hook it up. My main purpose is simply as a dwell meter. However, it has several uses. The setting on the dial show amps, volts, ponts, dwell, hi rpm, lo rpm.. and of course, there's the 8 cyl - 6 cyl switch. Any of you antiques know hook it up? The shunt looking thing some how connects to either battery or alternator. One site says to put the red alligator clip on the pos and the black on the neg sides of the coil... other sites say to put the red clip on the neg side of coil and direct ground to engine for the black clip... I'd love to know how to use all the functions. The two that I may have trouble with is "amps" and "good/bad points". If I knew how to correctly hook up the wires for dwell function I would have no problem making measurements or adjusting dwell. I have several engines that have point ignitions. Thanks for any help...
