braindead0
- Aug 26, 2003
- 169
I've been working on motorcycle, car, chainsaw..etc engines for over 20 years.. Just got my first 'newer' outboard (1989 25HP Evinrude).<br /><br />Long story short, I didn't know about the prime feature (push ignition switch in) and so I turned the electric primer to the manual position thinking it was a fuel shutoff valve. The engine started up pretty quick after I did that, so I figured "yup, must've been". It's amazing that it ran pretty good, spent a half day running it around a lake.. but it wouldn't idle very well ;-).<br /><br />So, now that I've read the repair manual cover to cover (and discovered that little tidbit). Are there any other things a motorcycle mechanic should watch out for? <br /><br />I was ready to rebuild the carb..thinking dirty idle circuit, hole in float.. stuck float.. etc ;-)
