- Jul 18, 2011
- 18,285
Hi Folks:
I am in the process of checking the structure of my boat for dry rot (or wet rot) as I have an opportunity to fix things before the boating season arrives in the northeast.
Long story made short . . .
(1) Last year I was doing some R&R on the engine mounts and as I tightened the starboard mount (thru-bolted not lagged), I heard a 'crack' sound. I discovered that the stringer was basically hollow and it appeared that the wood core had rotted away, but was not wet (so dry rot ???). See attached pictures #1 & #2 . . .
I repaired the stringer by filling it from the top with polyester resin to make it solid. The port side seemed to be OK, so I left it alone.
(2) I removed the engine last Fall to do some engine work and re-finished the bilge while the engine was out. As I was prepping the bilge, I noticed that the bulkhead was not properly glassed in and had rotted (this area looked more like wet rot).
I also repaired this area and added 3 layers of fiberglass mat. See attached picture #3 . . .
Everything is now solid from the outside, no soft spots or anything like that; the transom seems to be solid as well. HOWEVER, I am thinking that there are other areas that have either dry or wet rot beyond the 2 areas that I fixed. Before I put the engine back in I am wondering if there is a creative way to determine if other areas of the stringers & bulkheads are hollow on the inside. I tried a stud finder to see if I can determine solid versus hollow areas, but I'm not sure it is really telling me much.
My Question/Challenge . . .
Other than getting some fancy (expensive) infrared equipment, are there some other creative (i.e. economical) ways to check for hollowed (i.e. rotted) areas? As I said, everything is solid on the outside, but possibly hollow on the inside.
I was thinking that I could drill some test holes in various places in the stringers and bulkheads to see what it looks like on the inside. I'm just wondering if there are any 'clever' ways of checking without drilling.
Sorry for the long story, I hope that you did not fall asleep reading this.
T.I.A
Pictures below:
Pictures below:
