Any gas fireplace guru's in the house? Need help on installation
Homerr
I'm moving my freestanding gas fireplace into a corner of my home and unfortunately, I have misplaced my original installation instructions.<br /><br />I need to know what the approximate clearance I should leave behind the stove.<br /><br />I originally replaced my wood stove several years ago with a gas one. The wood stove sat on a rock hearth far away from the wall, so there was no issue of wall clearance.<br /><br />My gas stove does not get hot at all behind it and I know you can set them much closer to the wall than a wood stove.<br /><br />Anyone happen to have or know where I can look at a typical installation manual?<br /><br /><br />Thanks,<br /><br />H.
Homerr
Re: Any gas fireplace guru's in the house? Need help on installation
OK.... I get the 'DUH' award for the week... LOL<br /><br />I was trying to find the model number of the stove, and TA-DA!! the clearance dimensions were on an inner door of the stove...<br /><br /> :) <br /><br />It would appear that it only needs 3" from any combustible material. I think I'll double it to be safe.<br /><br /><br />H.
Bob_VT
Wow, glad we could help! :D :D <br /><br />That was easy! :D
AK_Chappy
Ok Homerr,<br />I am going to take a stab in the dark here and say you need at a minimum 2 15/16" clearance or thereabouts... <br />Your model number may need 3" though<br /> :D :D <br /><br />Glad you found what you needed.<br /><br />AK Chappy
roscoe
I'd crimp and solder those connections.<br />Then switch to synthetic gas.<br />Then you can reduce your clearance requirements by .00004%
