Any hints on properly stopping internal thread corrosion?
accentphoto
DSC_5385.jpgHow do you stop the corrosion that happens with threaded fasteners going into the Mercury Mariner block? Look at the photo to see what I mean. I have some of the waterproof lower unit grease if that helps or hurts? Suggestions? Ideas?
Fishing Dude too
Re: Any hints on properly stopping internal thread corrosion?
Galvanic reaction is what that is, switch to stainless steel bolt.
Ayuh,.... Coat the threads with Merc. Perfect Seal....
Maybe not a Cure, but it Helps...
accentphoto
I think I will rob some of the stainless from my older Merc Thunderbolt 1500 and grease it as well.
