Any info on this boat ?
Quadruplecccc
I found a 1987 22' imperial sportfish. Looking for any available info on this boat brand . I'm not familiar with it at all. It is a walk around cuddy. Has a 305 chevy w/ omc outdrive. I have a couple pics of this boat from seller that look good enough for a closer inspection, but hope someone has better ones to compare . Thanks !
a70eliminator
Re: Any info on this boat ?
There's no factory support for OMC being they've been out of business since the mid 90's. and it's difficult to find someone who will work on it when it breaks. Parts are still available through the aftermarket and if you can perform your own service then don't let it be a dealbreaker but use it to your advantage to bargain the price.
Compression check will tell you how healthy the engine is. check for soft spots on deck especially if carpeted.
