Re: Any recommendations on a battery and charger for a first time trolling motor user
3 thoughts, the 1st of which is you tend to get what you pay for in terms of batteries, and AMP / Hour rating is king - the more the better. I use the Wal*Mart Marine Deep Cycle which are serviceable for 4 to 5 years for me. The key to battery life is maintenance. If the battery is not maintenance free you just got to keep the fluid level up using distilled water; keep the terminals clean and connections tight, and; recharge immediately after use. A 10 or 12 AMP "smart" charger made for deep cycle batteries is ideal. The "smarts" in a smart charger will usually automatically lower amperage as voltage increases starting with a lower voltage, higher amperage bulk mode and ending with a tapered higher voltage, lower amperage finish. And the better smart chargers will include a de-sulfate mode, and if left connected to the battery after charging with automatically enter a maintenance mode to keep the battery fully charged when not in use. It's all simple stuff. Keep battery fluid level up, keep battery clean and connections tight, and recharge after use.
