Any Suggestions are welcome
pr73marine
Good day to all. I'm repowering my 32 foot 1967 ChrisCraft Sea Skiff. She is all wood and fiberglass. Im the 3rd owner.
She was 1st build with an I/O (not sure what it was I believe it was rated at 200+ hp) until the second owner decided to overhaul the boat with a new configuration.
The 2nd owner took out the original engine in the rear and put a 4 cylinder Isuzu diesel at midship with a shaft, brass prop, and rear rudder. He also added a pilot house and a keel made of fiber glass from bow to stearn. The boat weight is 12k lbs. at the marina's scale.
The problems is that she will not go over 7 kn at max RPM (2300) and now the engine is dead. I had an old lady pass me on a single paddle kayak and I have difficulty going under the Narrows Bridge in Tacoma WA.
I want to repower the boat with twin 150hp outboards as propulsion. I want to install an aluminum engine transom to the aft of the boat. Am I high smoking weed or is this a possible project? Any thoughts...
alldodge
Anything is possible, it all takes time and money
The main question: Is it worth what it will take to you?
