TwoRivers
- Mar 10, 2010
- 344
Hello all.
I'm looking for some advice as how to proceed?
Working on a 1997 E50TLEUC (50 hp Evinrude).
The tilt and trim assembly doesn't work and the PO gave me a rebuilt assembly to go along with the motor. The motor is not on a boat yet but on a stand.
I have a manual that says I need a special tool to remove the top pin?
I've got a cheap slide hammer that's not too heavy. I can probably weld a bolt that will fit the pin to a nut that will fit the hammer as I don't have the proper adapter. Does anybody have any experience getting the pin out? Will it take a lot of force? Would I be better off buying or trying to rent a heavier tool?
Also: The bottom pin that runs through the transom mount and the tilt assembly seems to be stuck.
Do you just pound this pin out? Seems pretty fragile?
Any opinions / options for getting this pin out.
Thanks in advance.
Rob
Thanks in advance.
Rob
