Any Toyota techs here?
tie_one_on
I'm looking for the banjo bolt size on a 93 4Runner with the 3.0L where you would hook up a fuel pressure tester. I'm thinking it is M12-1.25. Can anyone confirm this? Thanks
puddle jumper
Re: Any Toyota techs here?
You unbolt the cold start injector fuel line and there is a longer banjo bolt that you use.
tie_one_on
puddle jumper I was trying to confirm the thread size of the banjo bolt.
puddle jumper
I dont think its a 12mm more like a 10mm but i could be wrong
tie_one_on
Just to update in case anyone looks at this in the future the measurement was correct - M12-1.25. Bought the adapter from Actron. A whole $2.90 but shipping & handling brought it up to about $9.
Bigprairie1
...adapter?...as in a 'single' adapter item? Get the whole metric set. You definitely want to go metric...it rocks (imperial stuff is for 1970's lawnmowers)....and if you really want to win, get the Snap-on set. Its pricey but it makes for a successful job.
Good Luck
