Any tricks to get compression tester tube in?
cheers731
I was doing compression test on my 92 Four Winns OMC 5.8L Cobra yesterday. I removed all 4 plugs on starboard side but have no success to put tester tube in any one of the cylinders. The test tube is a 14" rubber with thread for cylinder side. Because the angle and tight space from exhaust manifold (EM), I wasn't able to put the tube in anyone of the cylinder. Does anyone have any tricks, tools or removal of EM is necessary to get this job done?
Thanks in advance.
Frank
airdvr1227
Re: Any tricks to get compression tester tube in?
It's a ***** and I have no words of wisdom. I promised myself that next time the manifolds were coming off.
Ayuh,.... Ya gotta remove either Boat parts, or Motor parts to get to where ya gotta be sometimes....
'ell, some boats, ya yank the motor, to change Sparkplugs....
Randy J
hmm well i got a old now, but new when bought it 25 yrs ago, a pressure tester back in my mechanic days. has the quick connect end like a air chuck. so way back then i bought 8 air hose connectors , that matched then just screwed however many cyclinders engine had and one by one test and wrote down the #'s and put in new spark plugs got er done. of course now it sits in shop as dont tinker too much on anything anymore.. when ya get older patience is short lolo
cheers731
Many thanks to your input. I guess finding a quick disconnect elbow or adaptor with correct thread will give me the best chance without remove the manifold. I will post back if I ever come up with one.
