Any way to reset an mpi without rinda tool
QBhoy
Hi
Is there a way to reset the mpi GM without the rinda ? Think I might guess there isn’t…but just in case there was a way around it. Thought I’d ask.
alldodge
Depends on what ECM
If its MEFI, turn key ON with jumper in service mode, then move throttle to WOT and return. Turn key OFF, codes should clear
QBhoy
Depends on what ECM
Ok. It’s a 555 ecu I’m sure AD. Tell me more.
QBhoy
Try a VesselView Mobile device.
Got one. I cleared the fault on that, but recently found out that the fault was still underlying when the dealer dialled into the vessel view. Fault been there since 2019. Thanks though.
