last year i changed out the stator rectifier and voltage regulator on my 200 merc 1988 O/B<br />it was charging for most of the season but i think it dropped off towards the end.....this year i suspect its not charging... i test my battery @ 12.63 volts and then run the motor and still get the same volts..<br />when i changed the stator i replaced it with a 14 amp ... instead of what was there i believe a 7 amp could that be too much for that type of REGULATOR ?? STATOR CHECKS OUT ... RECTIFIER CHECKS OUT
