anybody put boyesens on 60 degree
mnw001
I have a 97 115 carbed 60 degree and I'm wondering if boyesens would make a noticeable low and midrange difference on a heavy boat..<br /> and if anyone has done it. Boyeson uses the same part number for the reeds on the 60 as the 90 degree.
Dhadley
Re: anybody put boyesens on 60 degree
The motor will probably be smoother but it wont turn much more rpm if any. The rev limiter is still going to be at either 6200 or 6700 depending on which pack you have.<br /><br />The part number is the same for the 60* looper and 90* crossflow because they use the same reeds. They are different than the 90* loopers.
