Anybody tried using rubber flooring for boat deck?
Status
Not open for further replies.
erikpn
Instead of carpet, I'm wondering if I could lay rubber flooring down over epoxied plywood? It's nonslip, tough, and won't be damaged by water and easy to remove and clean. Plus I wouldn't have to mess with any more adhesives.
tashasdaddy
Re: Anybody tried using rubber flooring for boat deck?
other than being heavy not problem, there are several products for that. Commercial Kitchen Mats work well also.
Black will get extremely HOT!!!!
Ayuh,... It'll Work,...
But,...
Paint the epoxy 1st,.... epoxy don't like Sunlight...
stylesabu
Master Chief Petty Officer
i just painted my floor w/durbak.turned out great. its a rubberrized flooring. hers a picture
erikpn
But,...
Won't being covered with rubber keep it out of sunlight? I want to get a mat and cut to shape... no more messing with painting. I found some that is only 4mm in thickness, which should be enough to make a soft flooring and not be overly heavy.
Zetman
rubber sweats unless you have some air hole in it.
DK in Chicago
So what happened? Did you do it?
Love the Snap-On screwdriver in the picture, $60 may seem like a lot, but you'll never need another!
jigngrub
The wind blew his rubber matting overboard while he was underway because it wasn't fastened down.
I don't really know... seems like that might be a problem though.
Status
