Anyone else using an MR500?
lelyyy
Hey folks,
Just wanted to share a quick write-up on a scan tool I’ve been using for the past few months—it’s called MR500 and I figured it might help others dealing with Yamaha or Suzuki outboards.
A buddy of mine, who's way more engine-savvy than I am, recommended it when I kept getting mystery issues on my 2018 Yamaha F200. I’m no expert, but I wanted something that could help me figure out problems without running to the dealer every time. He said it’s built for these brands and not crazy expensive, so I gave it a shot.
Setup was pretty painless. The touchscreen is easy to navigate, and it connected to the ECU without much hassle—I just followed the steps in the manual. First thing I tackled was a random warning light. Turns out it was a fuel pressure sensor hiccup. Cleared the code, hasn’t come back since.
I also used it to track down a rough idle issue. Wasn’t the engine in the end—just a clogged fuel filter. Watching the live readouts (RPM, voltage, temp, etc.) helped narrow it down.
Build-wise, it feels pretty tough. I’ve fumbled it a couple times on the wet deck, and it still works fine. There’s a remote support option built-in too (like TeamViewer), but I haven’t had to use it yet, but it’s nice to know it’s there if I’m out on the water and get stuck—could call my buddy to walk me through it.
That said, it’s not for everyone. It only works with Yamaha and Suzuki outboards—so if you’ve got a Mercury or Honda, no dice. And while it’ll do basic system tests and read/clear codes, you’re not getting dealer-level access or firmware flashing. But honestly, that’s more than enough for most weekend boaters like me.
I paid around $550 for it—not cheap, but I’ve probably already saved that by not going to the dealer twice. If you're out on the water regularly and like to handle stuff yourself, it’s definitely been worth it in my case.
Just curious—anyone else here using this or something similar? What’s been your experience?
lelyyy
Just wanted to follow up... — the tool is from ANCEL.
Quick question:Their shows support up to 2022 — does anyone know if 2023 models use the same protocols?
