newbie4life
- Jul 19, 2007
- 410
Hi guys,
I have an older 40 hp yamaha that runs very well, doesn't need replacing -- and I don't want to spend (nor do I have the funds available) the several hundred dollars for an aftermarket power trim/tilt. I'm not afraid of doing a little bit of fabrication work on our pontoon's motor mount to make an actuator work. But I'm not sure how many pounds it takes to lift it before I order one? Obviously, lifting at the skeg is pretty light and easy, but If you move your hand up the shaft a foot or so, it's a little more work, and another foot, I don't think I could do it by hand. How does one measure the force required? I thought about a torque wrench on a fitting and see how it works to measure force... does this make sense?
Again, I'm not nervous about the fab work, but choosing the correct weight of actuator... 200 lbs, 400 lbs, etc.
Any help would be greatly appreciated,
Jason
Jason
