Anyone ever use this for there floor?
tashasdaddy
Re: Anyone ever use this for there floor?
i've considered it but it got pricey.
MASTER Brian
Looks kind of nice. You might also look into Hydro-Turf or Gator Grip. Both are really made for PWC turf, but can be bought in bulk and both would make a nice soft floor that's easy to clean! They may get pricey as well...
bassboy1
Never put it in a boat. But it came on a boat I was stripping. PITA to remove. Wouldn't rip. When it did rip it went into the smallest peices that still show up in the driveway after 4 months. The TUFF COAT rubberized paint worked real well though. Never taken it off but is easier to install I'm sure.
Boomyal
Yep Seaman! Wouldn't use anything else. Easy to lay, very easy to clean and very durable if you lay it solid. Here is a link for the best price I found.
http://www.a1foamandfabrics.com/site/department.cfm?id=11BE5A56-98C1-443E-A01FB5A6B3A61E36
hoytheld
What do you adhere with...contact cement????
Bob_VT
Click on the link and it also lists the spray adhesives. Looks affordable (filing that info into the old brain) :)
Mark42
Thanks for the link, Boomy! Saved that site in my favorites.
studlymandingo
Boomyal, that is one CLEAN looking interior! Thanks for the link. I'm not big on carpet for boat interiors, but with the new project I'm looking for some alternatives.
Boomyal
Hoytheld, I went down to my local auto upholster, with an empty, clean gallon apple juice jug, and bought a gallon of bulk contact cement. Price about 15$
I then used one of these to apply it. Although the glue looks pretty thick, it sprayed beautifully. I had masked all the sides up but didn't even need to do that. It was extra neat.
http://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=91011
I carefully fitted and cut the flooring then folded it in about 4 sections. I placed the folded material in mid floor so that as I unfolded it, it would lay in it's proper place. I sprayed the flooring then sprayed the floor in the same dimension as my fold. I had my son and wife hold the edges of the material in the air as I unfolded it and began to press it to the floor from the center out.
I repeated this for the second fold then turned around and laid the rear two folds.
If you have to have any seams or your edges are not concealed, as are mine, I would get some 2 part vinyl floor adhesive to apply to the first two inches at the seams or the edges.
Bob, when I ordered my flooring, they would not ship the glue. They claimed that it was classified as hazardous and cost too much to ship.
Thanks for the comment Studly. This floor has been on one crabbing trip now, with 5 Boy Scouts running around pulling up sand and seawead with the traps. When yer done, just hose it out.
I'm gonna lay that stuff, in a different color, in my 'new' Beachcraft. It has that horrible plastic carpet in it and it is full of sand.
