Hello All, new member here.
I have a question on this boat that i recently inherited with no info or manuals. Info on the net is pretty spotty. I know it was built in Canada and they are long out of business. They are a double bottom boat where a cavity fills with water from a hole in the bottom of the boat when docked to stabilize it. This water exits the same hole when you get moving and up to speed.
There is also a plug beneath the motor on the back of the boat. Is the cavity it accesses the same as the 'stabilizing. cavity or are they two seperate compartments?
I cant get the boat to plane and it feels 'heavy'. When i pull the plug that is in the bilge i get a gusher of water. I pumped and bailed for over half an hour and it was still coming. Just trying to figure out if i just have a ton of water in there to remove or if it wont stop gushing until i pump the whole lake out.
Thanks for any info you can share on this boat even if unrelated to my question.
And Happy Boating from Lake Scugog, Ontario
Dunkster
Dunkster
