Wow,
Thanks for the responses guys!
From what I’ve learned so far, and what I’ve been told, the new gauge and my sending unit are not compatible with each other.
Apparently there is some discrepancy between the gauge manufacturer and Mercury. Mercury Marine tells me that my Mercruiser is equipped with a 0-160 ohm sending unit. The original factory installed trim gauge would have to meet those same ohm values in order to operate correctly, which by the way it does.
So far, this all makes perfect sense because I have checked the ohm value of my sending unit which reads 10.6 - 159.8 ohm. With the adjustment screw removed, it goes as low as 1.4 ohm.
The Autometer people however, tell me that Mercury’s 2 wire trim sender is 0-90 ohm, and all their trim gauges are made with the 0-90 ohm spec. only.
Ok, yes, this is and has been confusing for me, but now I do know my trim sender is in fact 0-160 ohm as the people at Mercury Marine said it would be. And yes, it too is a 2 wire!
So, what’s going on here? Well, I’m not really sure, but I certainly would like to find out.
