Anyone have a picture of the 3 wire tim motor connector?
BigB9k
Looking for a picture of the 3 wire connector, on power trim/tilt units.
Want to make sure I get the pins in the correct spot.
Anyone have one?
emdsapmgr
The wiring diagram is not conclusive. It shows 3 wires (blu, blk, grn) going direct out of the motor. The ends of the wires look to be eyelets crimped on the end of each cable. Those ends screw to the terminal strip inside the control box. Unclear whether there is a rubber connectorssomewhere along that wire. No connector shown.
The newer system uses 2 relays to run the 2 wire motor.-----The older system uses a simple solenoid.------You need to find the wiring diagrams to be able to wire it up.---------Anything electric can be confusing and hard to explain to a novice.-------I do not bother with the details anymore.
interalian
I have a TNT from a '79 140 that's 3 wires. There's a wiring diagram inside the relay box. I'm not at home this weekend, but if you still need it I'll snap a picture when I get home.
