Anyone know what shaft length this is? (picture attached)
datoshway
I can't tell what shaft length this is. A little help?
Whoopbass
Re: Anyone know what shaft length this is? (picture attached)
short
BonairII
Looks like a long shaft to me.
Texasmark
You are probably running a 10" prop on that engine. So, scaling off that in your pic looks like 20"....pretty long for a 15.
Mark
Whoopbass
If you have access to the motor then measure from the under the lower motor cover where the motor block bolts to the bottom to the bottom of the skeg. If its roughly 30"-31" its a short shaft 35"-36" its a long.
Chinewalker
It is a short shaft (15-inch transom). The long shaft Johnrude 25/35 was significantly longer under the "horseshoe" at the base of the swivel bracket.
bonz_d
I have basically the same engine, Evinrude, and yes that is a short shaft for a 15" transom.
seahorse5
The model number will tell you.
