Anyone know what size spanner to use on my Merc Powerhead Nuts ?
murdmerc
I'm about to remove ... ahem...... Try to remove ... the powerhead from my 1991 40hp 2str. 4cyl. engine. I've disconnected all the ancilliaries and have cleaned up and being WD-40'ing the hell out of the 8 x nuts for the past 48 hours. Trying desperately to avoid bolt/stud breakage. The only thing is I'm a bit unsure as to what spanner to use - I only have metric and my 10mm is too small and 11mm too loose - I guarantee it is going to round the nuts - So reckon as it's an American motor I will need to buy an imperial spanner but there doesn't seem to be much available between the 10mm and 11mm size. Is 13/32 the correct size ? Anyone know for sure ? - The Nut is officially listed as 11-64809 - NUT (5/16 IN.) at http://www.hbmmercruiserparts.co.uk/blockparts.php?ind=543&bid=140 I guess that 5/16th is referring to the thread size.
See Nuts at : http://flic.kr/p/bvY7Bv
See Engine Details at : http://flic.kr/p/bvY7Bn
Have the main thread running at http://forums.iboats.com/showthread.php?t=532276 - thought I would get an answer quicker this way.
Cheers
sutor623
Re: Anyone know what size spanner to use on my Merc Powerhead Nuts ?
Dude how many places are you going to post this question? The big guys on this site do not like seeing this type of thing......
Don S
Might as well get yourself some SAE tools. 5/16" bolts typically take a 1/2" wrench. a 3/8" bolt takes a 9/16" wrench while a 1/4" bolt takes a 3/8" wrench.
There is no SAE wrench between 10 and 11 mm, 10 and 12 yes, but not 10 ans 11.
murdmerc
Yeah - It was a terminology thing - wasn't sure you guys were familiar with "spanners" so reposted and changed title to "wrench" wouldn't let me change title in the original post.
murdmerc
Cheers Don,
Will try the mole grips - the dremel and hammer and chisel - Ihave managed another 3 with my irwin damaged nut extractor socket, just the two under the front end now - how am I going to retorque these - troque wrench won't fit ?
Cheetah 210es
try 7/16th
