I've always had trouble getting adequate heat outta this van. Mine has the rear heater-A/C as well. There have been a few TSB's about the lack of heat from the 'sister vans' (Montana etc) but trips back to the dealer were a waste of time. Chevy is now installing an add-on aux. coolant recirc. pump to boost coolant flow but it's only a patch solution. I have checked just about everything I can think of , thermostats, hoses, coolant level etc , and all looks normal. This has to be a design issue, as others have had the same problem. This the first Chevy I have owned that wouldn't blow you doors off with heat. <br /><br />So that's the center of this post, to find out if anyone else is having , or has had the same problem, and how they fixed it (or not-as the case may be).<br /><br />
Still freezing , here in the Midwest........
