ngt
Master Chief Petty Officer
- Feb 26, 2009
- 874
Wiring up a trolling motor and new fish finder. Pretty expensive stuff and I don't want to mess it up. See anything wrong with this diagram? Anything I'm missing? The reason I'm using the terminal strips is because the connectors on the trolling motor are too small for the posts on the batter box. I didn't want to strip them and put on new connectors in case I need to return the motor for some reason. So I used the terminal strips to simply change the wire. They are rated at 100a and I have 8 guage wire (overkill?) coming off of the other end and going to the motor. The reason the front light has two positive wires is because it has an extra little light on it in the back for whatever. Should I mount in switches for the trolling motor and fish finder? Or will using their on/off feature be enough?
thanks!
thanks!
