Anyone use the outdoor carpet from lowes?
cold_gin
Going to replace my carpet on my 93 javelin bass boat and wondering if any of you have put it in your boat.
jcfitzgerald
Re: Anyone use the outdoor carpet from lowes?
Yes. I put some green color in my Xpress last year. It is holding up ok.
SDSeville
I used the Home Depot stuff and it has held up great for 2 seasons
jvanhees
what about for bunks? anyone use this for bunks as well?
jayhanig
Master Chief Petty Officer
I've got the Navy Blue carpet from Lowes on the deck of my Galaxy. It appears to be holding up well.
matt167
My dad used some grey from a liquidators years ago on his Chieftan. Held up great in the time he had the boat
bako88fan
I just replaced my bunks with pressure treated and lowe's grey outdoor carpet. So far so good.
BonairII
I have the gray marine stuff from Lowes. I like it a lot. It comes by the foot off a 6' wide roll. It's nice looking, has a rubbery backing, and doesn't snag hooks.
jvanhees
good info thanks
Tnriverluver
I have the same and after two years is holding up well. I do not let my boat sit out in the weather so that makes a big difference.
colbyt
I bought the 6 foot wide for the bunks. It is the only thing that sheds worse than my son's dog. The shedding is only along the cuts. I would say forget seaming this stuff; it ain't going to happen.
When I redo, I will go with the regular indoor outdoor stuff.
Jonnybbad
I've got some fairly old looking blue outdoor carpet on the bunks of my 245's trailer. That's how it came when I acquired it last fall. Don't know how long it's been there, but it seems to be OK. One spot where it was seamed it is unravelling a bit though.
Jonnybbad
Come to think of it my uncle always used indoor cut pile carpet remnants on his pontoon trailer even. It is nylon I suppose.
colbyt
The marine stuff is 100% Olefin. Indoor outdoor is usually Olefin with a different backing. I suspect as long as you stay with 100% man made you will pretty good.
BonairII
The marine stuff has better UV protection than the other outdoor carpet I saw at Lowes.
Stachi
I used the grey and the maroon from Lowes, two years and still looks great. A PITA to vacuum but I keep it covered when not using boat to keep dirt, leaves and U.V. off of it. :rolleyes:
Tail_Gunner
Picked some carpet from Lowes it was outdoor carpeting a bit swanky for marine carpet. Its held up since 2008 remarkably well....Far better than actual marine carpet.
cold_gin
Thanks for all the great input guys!!
brookieme
I also just put some of the Lowes marine grade carpet in my boat....brown....rubber backed. Came out very nice...and fairly easy to work with6.JPG :) Good luck...!
