anyone with a force manual plaese help
raveng60
i need to know how to troubleshoot my 50hp force '89 cd module assembly and the coils also. if you can direct me to a site i got a multimeter and all kinds of tools. thank you
roscoe
Re: anyone with a force manual plaese help
Need a DVA meter to read peak voltage.<br />Set meter to 400 DVA.<br />red lead connects to motor ground<br />cd has to be removed from mounting bracket.<br />black lead connects to orange wire output of cd, which has been disconnected at the coil end.<br />Crank the engine, observe meter, need 210 volts or more.<br /><br />Reconnect the orange wire.<br />Then test again on the red cd output wire. You need 210v minimum here also.<br /><br />If either is lower than 210, replace cd unit.<br /><br />If the cd check out ok, then check the coil output for spark.
