Nothing to leak oil from there, other side of that bushing is the exhaust cavity. If dripping there, then you probably have oil leaking from the output shaft seals on the upper case leaking into the exhaust passageway. These are the seals that the shaft coming up from the water pump go through into the upper gear case.
