I am unable to get any spark on my AQ125.
I have replaced the coil, distributor cap, condenser, points, and rotor button with all new parts. I have checked with a multimeter for broken wires and there are none. The coil wire was bad and I replaced it with a new wire.
I have checked the voltage going to the positive side of the coil and it is 12+ Volts. The voltage on the negative side is also fine.
Any suggestions would be greatly appreciated.
