AQ 125B Swap
JFrog
Hey guys,
Okay, I recently found out that the camshaft on my 1985 AQ 125B was pitted, the oil pump had seized and none of the parts to rebuild this engine exist.
So, since there are no parts for this motor any longer I'd rather not put one of these motors back in.
What are my options for an engine swap and where can I find these options?
I'd prefer a turn-key option that will mount directly to the bell housing and work with the 270 outdrive that is currently in the boat.
Thanks,
Keith
bruceb58
Re: AQ 125B Swap
That engine was a very common engine in Volvo cars. Your engine is either a B21 or B23. Should be able to find most of the internal engine parts very easily.
JFrog
Re: AQ 125B Swap
How do I find out if the block is a B21 or B23? Does it matter or do they have the same internal parts?
If these parts are so easy to find, why does it say all the parts are obsolete on volvo penta parts lists and the like?
I found a used AQ131A, AQ125A and AQ125B on ebay for pretty good prices. If I need parts for these engines, where do I find them? Is there a parts supplier you guys know of?
Thanks,
Keith
Re: AQ 125B Swap
the motor is a volvo automotive motor from Volvo that has been marinized by volvo. as Bruce pointed out, the motor is common in many Volvo cars.
JFrog
Re: AQ 125B Swap
I finally found out that the 125A is the B21 (2.1L) and the 125B is the B23 (2.3L)
JFrog
AQ125A vs AQ125B Camshaft
Does anyone know if the camshafts for these two motors are interchangable?
Thanks,
Keith
bruceb58
Re: AQ 125B Swap
You may need to go on a Volvo forum. I am thinking that when the B23 came out for the car, it also came with a twin cam and I am not sure when they did that for the marine engines.
JFrog
Re: AQ125A vs AQ125B Camshaft
Great resource Fun Times!
It looks like I can just get a completely rebuilt head with everything included for $300.
Thanks!
