Aq 131 leaking oil.from back of the cam
replaced my valve cover gasket thinking that was the issue but its the cam leaking. I can't seem to find a seal for it. If I look up camshaft seal I only come up with ones for the front, unless it's the same seal.front and back....
OK after more digging I finally found something....looks like its a.camshaft bore plug. Now to figure out how to remove it
