Re: Aq 280 Bellows Diy Or Pay
You don't have to remove the complete outdrive to change the bellows, it's only necessary to remove the upper gear box.
I think the job is fairly easy, but I have done several hundred of them.
One other thing you should check while changine it, is the water hose conntection. Then tend to corrode away and cause overheats.
Here is a thread the covers what you need to do.
http://forums.iboats.com/showthread.php?t=309095
You can also go up the the Adults Only sicky at the top of this forum and download the OEM manuals for your engine and outdrive.
PS> If you turn off your caps lock, you won't have every word capitalized like that, sure makes it hard to read.
