wausedboater
- Mar 24, 2017
- 3
Sorry about mis-posting this earlier today. I've not used this forum since 2017.
Question with AQ280 on my 1978 Glasply hardtop. Tilt quit responding to tilt switch on dash. Light on tilt switch also quit at same time. I hardwired tilt motor on unit to test. Tilt works perfectly both up and down. Doesn't seem likely that relay is the problem as what are the chances light on switch would quit at the same time as the relays (?). Wiring diagram shows a 20 amp fuse in circuitry. Can this be the problem and if so -- where is the fuse located?
I can still use the boat with my homemade circuitry back on the stern but I'd like to make it right. Thanks, Mark
