What is the proper way to fill the cooling system when it is empty ?
W whitetail16 Recruit Joined Jul 18, 2021 Messages 3 Jul 18, 2021 #1 What is the proper way to fill the cooling system when it is empty ?
Scott Danforth Grumpy Vintage Moderator still playing with boats Staff member Joined Jul 23, 2011 Messages 50,947 Jul 18, 2021 #2 with heat exchanger, thru the radiator cap without heat exchanger (seawater cooled), launch boat, it will automatically fill when the pump starts spinning
W whitetail16 Recruit Joined Jul 18, 2021 Messages 3 Jul 18, 2021 #3 I do have a heat exchanger , expansion tank etc Do I put in antifreeze ?
Scott06 Admiral Joined Apr 20, 2014 Messages 7,036 Jul 18, 2021 #4 whitetail16 said: I do have a heat exchanger , expansion tank etc Do I put in antifreeze ? Click to expand... Yes same as on a car
Scott Danforth Grumpy Vintage Moderator still playing with boats Staff member Joined Jul 23, 2011 Messages 50,947 Jul 18, 2021 #5 yes, with a heat exchanger, you put in a 50-50 mix of antifreeze
