AQ120B / 270 Exhaust hose - seeking info on replacement
DarrellK
I need to replace the exhaust hose that connects the exhaust manifold to the exhaust pipe leading to the lower unit. exhaust hose.jpg
The hose is not uniform in shape, but has a manufactured bulge in the middle.
Question.
1. Do I need that hose design, or can I use a straight exhaust hose?
2. What is the purpose or function of that shape of exhaust hose?
Thank you
alldodge
Question.
Thank you
The bulge is designed to allow the boot to flex more then a straight hose. I would suggest that if your engine had this type on it prior you should replace with the same type.
DarrellK
Thank you AllDodge,- that makes sense since the exhaust pipe is fixed and the engine is on mounts. Much appreciated.
cmcbob
did mine yesterday had to take off exhaust manifold less than 1 hour bought boot from Merck dealer $40
