Re: Aq125 carb issues?
Do you know when things need to be adjusted to?
What?
Good, timing is set, now adjust the carb. There are 3 adjustments: idle, mixture, and accel pump.
Start by warming up the engine. Set the idle (900rpm in gear in the water, or close to 1100rpm at idle on muffs). Then adjust the mix a little to see if it sounds better a half turn either way. When the mix is right it will probably bump up the rpms a little. Readjust the idle. Then adjust the accel pump.
If you punch the gas and it hesitates or stalls, the accel pump is probably not squirting gas on demand. You need to back off the adjusting nut on the rod to make it squirt the gas sooner. There is a point where too soon is not good either, just tweak it for a few minutes and you should have it figured out.
