Craigmail361
- Nov 18, 2017
- 20
i have the famous aq125, but I’m new to these engines.
The boat was sitting for years and finally got it running but my problem
lies with the carb and cooling system.
i rebuilt the carb with a new rebuild kit and seems to be running fine, but if I cover the small hole above the idle jet on the big plate where the air
filter sits, then it runs and revs, if it’s not covered, it dies and lags.
Pictures below...
and the 270 doesn’t seem to be sucking in raw water with the muffs, so I
took off the connector from the water pickup tube (chrome tube) from the
inside the engine compartment and connected it to the rubber hose with the
garden hose, I assume it was pumping water cause of the big vapor cloud
coming out of the exhaust.
i think I need an impeller and please tell me what u think. I need to know what the hole on the carb goes to as well. Please let me know what I’m missing thanks!
Pictures below...
