AQ125A exhaust downpipe o-ring
series60
Trying to locate the AQ125A exhaust downpipe o-ring. Need part # or web address to order. TIA
series60
Big Big thank you. This is my first VP AQ125/270 so I going slow and trying to learn all I can. Been thru Mercruisers most of the time. At 70 yrs old it's always good to keep the grey cells working. I have both the engine and outdrive manuals and a lot reading on going.
captmello
You're welcome. Those motors are very common still these days. If you're going through the motor, I would suggest replacing the timing belt. You can use an automotive belt and save money on parts. Also repalce the belt tentioner while your in there, also an automotive part.
Volvo still seems to support that model so parts are easily available.
goto the adults only sticky at the top of the volvo penta forum and click on the volvo info (#2). There are some useful posts in there for your research.
Good Luck, let us know if you need further assistance.
jerryjerry05
They have a link to Volvo Penta parts here.
Top of the forum, you see a pic of a black sterndrive.
Click on that and follow the lincs and it will lead you to the Volvo parts.
Your motor is listed there.
