I recently aquired an 83' bayliner with an AQ125a and 270 outdrive. We got it in the water this weekend for the first time and all in all the boat performed very well. I have two questions though:
1. When the drive is in gear and throttle is slowly applied it will start to accelerate and then the motor will stall around 2000RPM. If I go from idle to near WOT or greater (3000RPM) the boat accelerates beatifully and runs smooth. Once the boat has gotten up to plane I can pull back on the throttle no problem. It doesn't do this when in neutral and it will idle without issues. Where should I start looking for issues?
2. When going in a straight line the boat sounds great, but when I start to turn in either direction I hear a "groaning" sound and some vibration coming from what I believe is the outdrive. Is this a sign the u-joint is going out? If so, how can I tell if they it is bad?
Thanks for all the help.
