Aq131 timeing advice needed.
Hi there, got a timeing belt issue that I havnt been to really find info on what im looking for.
so my aq131, the timeing belt had slipped, replaced the belt retimed the cam, every thing seemed swell on the brief dry fires, put all back together, and ran some water to outdrive,
after running it for a few mins I upped the engine speed and timeing slipped again. Now I already planned on replacing the tensioner, but I'm wondering if it's worth the time and money to replace the cam.gear as well, visually my current cam gear looks fine.
alldodge
Normally a belt will not damage the gear. I would use it again being your saying it looks fine
kenny nunez
As long as the cam, crank & distributor belt gears are not rusted they should be good. What is wrong with your tensioner?
Was your old belt damaged?
I serviced those engines and never had one throw off the belt after I replaced one
The new belts had the timing marks and to make sure everything was lined up I would spin the engine with the plugs out, after about 25 revolutions the belt would “walk” around to the original starting point. If it did not then I would re set the belt and check it again. Sometimes the tensioner would cause the belt to jump a tooth.
The boat has seen some saltwater but the timeing gears have very minimal corrosion
I was more less looking to see if the cam.gear.was a known issue on these engines
thanks.guys
post a pic of this "minimal corrosion"
I would replace the tensioner
kenny nunez
If there is ANY rust on the gears it will eat the belt up in a very short time. They are not hard to remove and have them glass bead blasted.
Sorry for the late reply been to busy to get back to the boat.
the cam gear looked good, until it rained with the cover off (damn oregon) so ill pull that and clean it up..
Tensioner and new belt came in any tricks for putting the new tensioner together having a hell of a time getting it back together
Update on the tensioner assembly.....finally found a video of some one doing it, and I feel super dumb for not thinking of this haha
