AQ131 With High Oil PSI, What Would Cause This? Thanks.
Gwozdz
Have aq131 4 cylinder engine seems the oil pressure running high around 80 blowing oil into my crankcase vent hose which is blowing into carb what's happening?
alldodge
Blowing oil out the crankcase vent hose comes from engine blow by which is caused by worn piston rings.
High oil pressure readings might be from a bad gauge. Need to get a hand held gauge to check yours
dennis461
" Volvo oil pumps are top quality and rarely fail, but they can suffer from abuse due to built up sludge in the oil pan. Another problem as pumps age is sticky pressure relief valves that can cause too much for too little pressure. If you are having oil pressure problems and you have ruled out any problems with bearing clearance, a new pump may be in order. Always install a new pump when rebuilding an engine."
