I have an aq170 with a corroded exhaust down pipe. How do I access the bolts for the down pipe? On the engine side or the outdrive side? It is connected to a 270.
Step 1-remove upper unit on your aq270
step2-take out bellows
step3-remove 4 bolts holding exhaust pipe from the leg side
step4-remove 3 bolts holding exhaust pipe elbow(the very end of exhaust manifold on the engine)
step5-remove rubber pipe connector and exh. pipe.
