Thanks for the reply scott!
Ok, yes ill give that a go, im assuming you mean just the ones that are reading the lowest? Do i spray each one individually then instantly check the compression on that cylinder?
Can i run my boat with the readings the way they are? Im pretty sure nothing much has changed from last year when i used it, although running rich i seemed to have enough power to explore these narrow rivers here, i barely go over tick over, the speed limit here is 7 mph (big engine for this application!)
Possible the valves could be mucky then? The engine has been running rich for sometime causing sooty build up on plugs on a regular basis, can this effect the valves?
Its been in fresh water for at least 5 years, ive owned it 2 years.
The exhaust manifold looks ok, Ive had the water pump rebuilt, rebuilt the sea water pump as it was leaking slightly. new plugs, new leads, oil and filter, new starter. new alternator, Ive rebuilt the cooling system and installed a venus water filter. Installed a venus fuel filter/water separator. Cleaned and inspected oil cooler.
Next on the list is a carb rebuild (kits on order), recently had trouble with starting, ruled out fuel pressure but i do have a weak spark, later today im installing a new coil and readjusting points. Cranks but doesnt sound like it fires.
I need to start posting up pics, going to try and revive my photo bucket account!
thanks
Mark
