AQ171, which oil pressure gauge is needed (bars)
Myrland
Hi!
I am new to inboard motors, and have a AQ171 in my boat.
I need to install an aftermarket oil pressure gauge, as I have removed the old volvo gauges.
Wema has oil pressure gauges in the following models:
0-5 bar (75 psi) and 0-10 bar ( 145psi)
I have read the workshop manual for the AQ171, and can't find anything on what the oil pressure should be.
Any help will be greatly appreciated.
Ayuh,..... Welcome Aboard,..... The rule of thumb is, 10 psi per 1,000 rpms,.....
So the 1st gauge,....
unless the stock spring is changed in the PRV on the oil pump, the 0-5 bar gauge will be fine.
