loco
- Apr 25, 2010
- 154
Hi all,
I've got an AQ205A - it all works OK, but it's quite old and I'd like the extra power and efficiency of an EFI model.
I quite like the look and price of this model here: Brand New 4.3L V6 MPI - Repower Marine Ltd.
so, my engine is the 4.3L GM engine before the balancer shaft. The one above is the 4.3L with balancer and of course the EFI system.
I'm trying to find out what I can keep and what will need to be done. Things I've been thinking of:
Drive leg: can I use the engine bell from the current engine and mate the above to my DP290 which is in reasonable condition?
Instruments: will the RPM/temp/oil pressure instruments from the AQ205A connect to the new engine?
Throttle cable - will a carb cable fit an EFI engine?
Exhaust headers - think these will bolt right on
Coolant system: will the same raw water hoses fit? I'm thinking about getting a closed cooling system conversion kit for the new engine so it runs hotter and doesn't get fillet with seawater
Alternator/power steering pump/starter motor I'm assuming will bolt right on too.
What do you think?
Thanks in advance!
What do you think?
Thanks in advance!
