Hello all,
I have a 1986 AQ225D, with a quadrajet I just purchased re-manufactured off ebay. I just replaced the fuel filter, fuel pump, starter, and alternator. I have set the timing to 8* and triple checked it multiple times. It starts and idles great! But if I give it any gas, it falls on it's face and dies. IF I hold the choke almost closed, it allows me to rev it up just fine. I get about 15 vac using the nipple that would be going to the little metal vac puller thing. I have gotten it all the way warm, letting it idle for over 10 minutes in a bucket of water, I'm glad the water pump works good. I did have a vac leak on the bottom right "port" where the electric choke would be, but plugged it with some tape. Same issue. I have used a tube up to my ear to find any other hisses or leaks, and I can not find any. I am starting to think there is something wrong with the carb, possible incorrect jets? It is a 305, if he put in 350 jets, would that cause a problem like this?
Thank you.
Thank you.
