Aq231a Outdrive, dry start up
Tom french
Need to check if engine is ok after winterisation (no leaks etc) and before back in water, so looking to start it up. Any suggestion on getting water through. Can I use flushing muffs and if so is there a specific type or recommendation.
Make sure to ues the AQ specific muffs and plug the bottom pickup hole with a rubber cork
if you havent pulled the drive to inspect the u-joints and bellows. now it the time to do it. specifically inspect the water inlet casting on top the pivot pin
QBhoy
Hi. Muffs are a 50/50 on the drive that will likely have. I’d personally have a hose directly to the water pump.
