AQ260 stalls at low RPM and tough to re-start when hot
Starts really well when cold; runs great until I need to bring the RPM down (idle-1000, 180 degrees) for docking etc; tough to re-start after I shut down, or it stalls when hot (180 degrees).
Any ideas?
Very much appreciated.
Chris
captmello
Re: AQ260 stalls at low RPM and tough to re-start when hot
When was the last full tune up?
Tuneup maybe 15 hours ago; fuel filter last year...
captmello
It sounds like your ready for a carb rebuild.
Ayuh,... Fuel filters don't have an expiration date, but if it took on water, it needs changin',... Again....
More importantly, is what's IN the filter.... change it, 'n LOOK...
captmello
Bond-o is right, of course(im sure he hears that from the wife all the time)...empty the fuel filter into a glass jar and let is sit for a while. While it is settling, go get a new filter. If you find the gas to water free, I would proceed with a carb rebuild or replacement.
Let us know what the fuel looks like.:)
Checked the filters, found gummed up fuel pellets. New Racors on order. Won't be able to test for another 10 days or so... It still seems like there might be some sort of ignition issue because the the stalling at idle only happens when it's hot. One issue at a time.
Thanks for the great help
Chris
Well, it looks like the coil was the issue. Ran perfectly all weekend. Maybe it was loosing contact inside when hot etc. That being said, the fuel filters definitely needed to be changed.
Thanks everyone for your ideas!
Chris
