aq270
Tommy123$
i have a aq270 outdrive and I acidently started the engine in the trailer up position does that do any damage. only ran it like 15 seconds
Welcome aboard
its not good for it.
pull the drive and check the u-joints
JimS123
You have to service the u-joints anyway. Lots of people don't even know that.
Regardless, my uneducated opinion is that 15 seconds didn't destroy anything. We've all made that mistake once or twice.
is their any other way to tell with out pulling off the outdrive,
Noise maybe
pulling the drive (or at least pulling the transmission off the drive (see the stickies) is a once-a year maintenance issue. while you are inspecting the U-joints, you may want to also replace the bellows and check the PDS bearings
72fj40
You can pull the upper gear box instead of pulliing the whole drive.
